iPhone 7 plus keeps shutting off after screen replacement
I just did a screen replacement on an iPhone 7 plus. The previous screen was almost completely shattered with a large hole in the upper left hand corner.
After I completed the repair, I turned the phone to find that everything worked fine. The camera, microphone, audio, etc... all worked great. I left it on for a few minutes just to make sure everything was fine, and while I did that it turned itself off.
Now I can't get it to stay on. It'll stay on for anywhere from 30 seconds to 10 minutes, however at some point it will shut itself off. Sometimes it'll shut off when it would usually go to sleep. Sometimes it'll shut off when the lock button is pressed. I've tried disconnecting the flex cable (for the camera, light sensor, etc), and it still does the random shut off thing.
Other than that, there doesn't appear to be anything wrong with the phone. When I leave it plugged in, I don't believe it does this shutdown thing (however I haven't had a chance to test for an extended amount of time).
Has anyone experienced this before, and did anyone come upon a solution?
7 Comments
I've ordered a new flex cable. I'm unsure if this'll fix the issue, but it's worth a shot.
by JoshuaCu
Only thing I can think of is the battery being faulty, if not it probably needs at least board-level repair / microsoldering to fix the problem.
by Ben
Did you ever find a solution to this?
by Dalton Prokott
I had the similar issue with iPhone 7 screen replacement with grade AAA screen. New screen was working fine after tested everything, Now, when I closed the new screen on the phone to put final two screws, display just disappeared and was tuning on and off and it is keeping turning on and off for long.
After that I did not try anything else.
I am assuming it is because of non-original screen?
or its battery went wrong with new screen
or it need to connect with itune to repair software.
or shall I try original broken screen back
What do you think ?
by iRepairMan
My iPhone 7 Plus is doing the same at the minute, I took it back to the shop where I got it repaired and it started working fine but it didn’t have a SIM card in, for a good few weeks I left my SIM card in my spare phone and was just hot spotting my iPhone and it worked fine and wasn’t cutting off and as soon as I put my SIM card back in my iPhone it starts cutting off off! Is this because the screen has not been put on correctly??
by harriet
Show 2 more comments
