The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
331 Questions View all
Washer doesn't fill with water on rinse cycle.
Kenmore washer does not fill with water for rinse cycle
Score 1
Add a comment
1 Answer
Chosen Solution
If the washer drains after washing but will not fill in the rinse cycle then checking the pressure switch would be a good idea. If the tub is empty you can remove the plastic hose, give the switch a thump and reattach the hose. Does it fill now?
If not then you can remove the violet wire and tan wire from the pressure switch and join them together with a small piece of insulated wire.
Remember to unplug the washer first before attempting this.
With these two wires connected the washer will fill if the pressure switch is the problem.
Score 1
Add a comment
Add your answer
Cindy will be eternally grateful.
Past 24 Hours: 23
Past 7 Days: 76
Past 30 Days: 294
All Time: 1,742
