Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2686 Questions View all
iPhone 6s Backlight working but no image
Hello, i was changing my screen after i dropped and cracked my old screen on my iphone. I ordered a new screen and put it on the phone. Turned it on. The backlight lit up black but no image. Thought it was the replacement screen so i put the original screen back on. Same thing backlight lit up but no image. Ordered a new screen and still got the same thing as before. Is there a problem with the logic board?? I didn’t disconnect the battery first or screw down any screws.. please help
Score 1
Add a comment
1 Answer
Chosen Solution
If none of the screens work, including the original which I assume worked before you replaced it, then you probably have a logic board issue. Not disconnecting the battery can cause a backlight circuit failure and occasionally, it could also cause an LCD driver issue.
One way to know for certain is to shine a bright flashlight on the screen when you connect it to an iTunes enabled computer. If you can see a dim image, then the problem is with the backlight. If you cant' see an image at all, then the issue is with the LCD driver.
You should also check the connectors and surrounding area for any damage pr dislodged components. Use magnification as the parts are really small.
Score 1
1 Comment:
What do you mean by the LCD driver issue because I also had this problem that the blacklight is on but the image don’t show and touches works.
by
Add a comment
Add your answer
Marcus Mathis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,227
