Clone dual boot drive (Mac/Bootcamp) that can't boot?
I have an iMac with a hard drive that (partially) failed.
It was loaded with the iMac OS (which I didn't use) and bootcamp. I was able to remove it from the iMac, hook it up to a PC and get all the data off of it that I needed. It seems to be pretty unreliable, and will not boot.
I purchased an SSD and would like to to install it in the iMac, running windows. I tried cloning the Bootcamp partition (EaseUS Todo Free), but installed in the iMac it just game me a folder icon with a question mark, would not even boot to a drive selector screen.
I'd prefer not to repurchase windows or Mac OS, although it looks like I could get Mac OS pretty cheap.
The SSD is the same size as the old HDD.
I've tried loading the old drive as a USB (USB-SATA cable) but the iMac didn't recognize it. I'm thinking my next steps would be to try a mac bootable USB flash drive (of course I can't find one at the moment), take both drives to Simply Mac and tell them to make it go, or. . .
Suggestions?
Thanks,
Dano
2 Comments
Are you sure you've selected the correct model here??
Both the 2011 21.5" & 27" use a 3.5" HDD drive in this series. The newer 2012 models onwards use a 2.5" in the 21.5 and a 3.5" in the 27" HDD. Only the 3.5" models need the in-line thermal sensor when you swap out the drive.
by Dan
Yes, this was a 27" with 3.5 inch HDD which needed the in-line thermal sensor. For now, it has again failed, even with the new hard drive, so it's off to see a diagnostician smarter than I am.
edit: I just figured out what confused you. when I said the new SSD was the same size as the HDD, I meant they are both 1 TB. The SSD is 2.5", the HDD is 3.5"
by Dan Robrecht
