How to restore Apple TV 4K (Without USB-C)
Hey,
Usb-C port is not available on AppleTV 4k Edition.
How is it possible to connect Appletv 4k to ituens ?
I heared ,something about recovery/DFU mode over a WiFi connection
I asked this question in Official Apple community Forum,but nobody answer.
According to this link:
https://support.apple.com/en-ca/HT203028
If you see a yellow warning sign, while trying to update the software on your Apple TV 4K, contact Apple Support.
Is there any secret approach?
Best regards
6 Comments
I have reviewed all comments
Base on that i have two question,
1.Holding down remote Menu & Home Screen button at the same time for about 5 or 6 seconds, for soft reset is working for Apple tv 4k edition ?
2.According to your guess , we should connect the appleTV 4K to iTunes by using HDMI <-> USB cable, already there is HDMI<>USB cable on the markert (Bestbuy/Walmart,Amazon,...) , we can use them ?
And what is exact procedure for restoring the Apple TV 4K by using this cable?
by Reza
I just successfully restored our AppleTV that we'd given up on with a suggestion I found here (https://www.reddit.com/r/apple/comments/...).
The thread is archived so I can't upvote it, so spread this solution, because that Reddit thread's the only place online I was able to find it!
by gyffes gyffes
@gyffes gyffes < Thanks for your info, but that's not a real solution, we don't just want a reset it but also firmware upgrade/flash it either via cable or over WiFi. The only working solution I've read about is using the latest X-Code over WiFi, but that's only available on Macs since it's part of that eco-system. Problem is two thirds of people around the world use Windows, Linux, etc.
by billa.4you
That’s a funny comment: the subject was “how to restore...?” annnnnnnd that’s what I offered in a non-OS-dependent method. In a thread on how to make chocolate, I offer a recipe, and yet you complain my method won’t convert lead to gold. Hmmm
Yeah, it’d be great if Apple hadn’t removed the USB port, but since they were trying to preclude the very thing you’re desiring, it certainly makes sense why they did it from their perspective.
As Chris Rock put it: “Ah don’t approve, but Ah unduhstaaannn’”
by gyffes gyffes
@billa.4you where did you see the procedure about using Xcode? My appletv 4K has the support.apple.com/appletv/restore error and it isn’t fixed by the procedure outlined in @gyffes message
by Dwayne Rich
Show 1 more comment
