Why wont my iPhone hold a charge
My I phone was not holding a charge. I installed a brand new battery and it still doesnt hold a charge. What else could be the problem?
Lucas, it may hold a charge but is not getting any power through the charging circuit. Check your dock connector and make sure that it is free of corrosion and that there is no debris. and that all the pins are straight. Also make sure that you have a good cable, that you try a different USB port and / or check your AC adapter. Also, since you changed the battery, triple check your work to make sure it is okay and that all connections are properly seated. Good Luck and let us know how you are progressing.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 949
