Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
LCD replaced. Won't power on
Hi i've replaced the lcd of my Iphone 6 everything went great and once i put in the ribbon cable and tried to start it there were no signs of life. So i did the usual check, i tried another lcd, same thing. I connected the phone to the computer and it recognized the iphone but there is no vibration, no signs of life from the phone itself. I can feel the cpu getting hot but nothing else. Thanks.
Add a comment
Most Helpful Answer
The display connectors are really tiny and precise. I recommend using a hand ESD-safe blower to clean and a portable microscope to that check both sides of the connectors are truly dust free. Remember this phones are assembled in clean rooms, and our benches usually are a mess...
This has happened to me before. I hope the probable short-circuit (chips heating up) has not toasted the boards yet.
Cheers!
Christian
Score 1
Add a comment
Probably a blown backlight circuit, you can confirm this by turning on the phone on and using a flashlight to look for dim apple logo on the screen.
Other cause could be damaged touch / display FPC connectors on the logic board that would usually need to be replaced.
Both issues are solved via board level repair / micro soldering which you may be able to find someone that does it in your area
Score 1
Add a comment
Add your answer
Oskar Lindborg TE3B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 32
