Model A1236 / 4 or 8 GB capacity
146 Questions View all
Why isnt my iPod nano working!?
My friends ipod Nano broke and it doesn't want to turn on! @%^! put it on his ihome it says its charging but that's all it does! It refuses to turn on! I can fix it for him but i need to know whats wrong with it first and I cant risk dismantling it since its not mine. His ipod is the 3rd generation Nano. Any advice?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
Shade, it all depends how it broke. It could be as easy as to try to reset it by following the instructions from Apple to a complete dismantling and replace of logic board iPod Nano 3rd Generation Logic Board Replacement . But start with the reset and see what happens.
Score 2
Comments:
Thanks ill try that. My friend gave it to me and it doesent mater whe i return it but from what its doing right now it looks like the logic bord got either wet some how or it needs to be replaced for some odd reason.
by
Add a comment
Here is how to deal with it
Reset it
This is done by pressing and holding the center button and menu button till the screen goes black, then it will turn back on
From there, you have to restore it, which wipes everything on it, so keep that in mind
You will need iTunes and a USB cable some way, if you don't have one to use
Install iTunes and open iTunes, and then click on the iPod
here is a link to iTunes if you need it
http://www.apple.com/itunes/
Here is a admittedly crude visual aide when you open iTunes and the iPod is plugged in, because let's face it, crude visuals are better then me explaining it
Also know the white box is because I did not want my phone's serial # and phone number out there, so don't worry about that
If a restore does not help, replace the battery, but mind you it will need to be soldered in
Here is the guide
iPod Nano 3rd Generation Battery Replacement
here is the battery
iPod nano Gen 3 Replacement Battery
As to the soldering iron, a cheap one that gets to 450-500 degrees is enough, be patient, lead free is tough to melt
Add a comment
My iPod Gen 3 Nano is dead. Initially I noticed the light flickering on it for the past two weeks. Now it is completely down. When I plug it into my computer nothing happens... no charging will help this. I have over 2000 songs on it and only 100 are on my itunes ipod acct. Can I fix this? Will I loose all my songs?
Please help
lcook762@yahoo.com
Add a comment
Add your answer
Shade will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,243
