I have the poloroid Q10 tablet,battery replacement?
Hello as stated in the tiltle,I have the poloroid Q10 10" tablet and in need of a replacement battery for it. Any suggestion as to where I can find one? Thanks
Hi @tim57064 ,
Here is a link to just one supplier. It is not a recommendation to use them. It is shown to give an idea of the cost of the battery.
If you search online for a 4297108 3.7V 5000mAH Li-po battery you will get results for other suppliers.
The 4297108 refers to the dimensions of the battery.
42 =4.2 mm depth (or thickness) >>> note the decimal point <<<
97 = 97 mm width
108 = 108 mm length.
You may find that you cannot get the exact size in a cheaper battery but there are some that are available that are just a bit smaller, with the same 3.7V 5000mAH specifications. You may wish to consider these as you should be able to "pad out" the battery area or hold in the battery securely using tape etc. Just ensure that the depth (or thickness) is not more than 4.2mm.
Hopefully this is of some help
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 152
1 Comment
Hi Tim,
I to have a Q10, Did you have any luck finding a Seller, Also might you be able to send me a pic of your old Battery, The supplier I have been chatting with seems to want to have a pic of it.
Cherrs, Rob
by rbrtmacdonald4
