Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1954 Questions View all
Dead iPhone 3GS. Any reasons?
I tried to charge my iPhone 3GS and while it was charging. It turned itself off, The battery was at 98% when it turned itself off. It didn't show any error. Just turned off while I was browsing in Safari. I unplugged the charger. Which is the original Apple charger. But after that phone became really hot. I left the phone for about 2 hours when I came back it wasn't hot anymore but it won't turn on. I tried holding the Home + Power button. Tried to get it into DFU mode. Plugging into PC or charger doesn't work either. Can you guys tell me what may be wrong with it? Is it the logic board or the battery?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
try first the battery....... change it.. if not
its on the motherboard... on pm ic.. was shorted.. i encounter that problem but theres no solution... beacuse theres no availabale in the market..
Score 1
Comments:
I think I have a power IC for iPhone 3GS on eBay. http://cgi.ebay.com/iPhone-3GS-Main-Powe... I would try the battery first. If not then I would get the service for power IC.
by
Add a comment
Most Helpful Answer
mystikal, I would start with the battery. It is not very expensive toreplace and readily available. Once you have the new battery installed and should still have problems, at least you know that the battery is good. Makes it easier for trouble shooting. iPhone 3GS Battery Replacement and the battery is available here iPhone 3GS Replacement Battery GoodLuck and let us know.
Score 1
Comments:
It turns out it's the power IC. I have given it to a service centre for diagnostics though. Let's hope it gets fixed. Thanx a lot for your response!
by
Good that you got it figured out.Lets hope the cost for repair is economically feasible. Good Luck.
by
Thanx. It turns out it WAS the power IC after all. Got it repaired for 100$. Phone is working fine now :)
by
Add a comment
Add your answer
mystikal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,273
