Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Questions View all
There's dust under my IPad mini's screen
So there's a dent on the side of my ipad and there's dust coming in from it. Is there any way I can get the dust out? If not how much does fixing the dent and getting the dust out from under the screen cost? Edit: here's the dent
Add a comment
1 Answer
Chosen Solution
Could you post a picture of the dent? I want to see how bad it is and if it will still cause problems after removing the dust. Adding images to an existing question
To remove the dust you should remove the front panel iPad Mini 3 Wi-Fi Front Panel Replacement (you only need to go up to step 29, as you are not replacing it) and then clean the display with a microfiber cloth.
Microfiber Cleaning Cloths)
Update (02/06/2018)
bad dent there. the [linked product missing or disabled: IF145-280-6] should fix it!
Microfiber Cleaning Cloths Image
Product
$3.99
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
iPad Mini 3 Wi-Fi Front Panel Image
Guide
Difficulty:
Difficult
45 minutes - 3 hours
Score 1
Add a comment
Add your answer
andretran41 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,627
