Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
156 Questions View all
My DSI XL can't start any Application
My DSI XL boot normally, but it not able to start any application.
For exemple, it doesn't start wrench icon or camera application on dsi menu.
It not able to start any game.
o got this error:
"an error has occurred. press and hold the power button to turn the system off"
But a can start camera cliking on "L" and "R" buttons.
So, i can't perform factory reset on DSI menu.
How could i reset it phicically?
Tks.
Alexandre Bezerra
Score 4
1 Comment
Observe if you the problems them me. in my case the dsi wasn't able to open any application, include wrech icon.
Try disable wifi wpe2.
do you have any slot card?
by
Add a comment
Most Helpful Answer
I had the exact same problem. It was my first attempt at a repair, so I did a ton of work that was not necessary. Long story short, it was a simple fix.
The small wifi sub-board went bad. swapped it with another and all the symptoms went away.
Again, the exact same problem as you - camera works, can't load any application (system settings, insert game, pictochat) or the same error you posted occurs. If that wasn't the problem, I'd be surprised.
Score 5
6 Comments:
You need to replace the Wi-Fi module. Good Luck. Next Level, PR
by
Hi, I have the same problem, but I have no idea what you mean by swapping the small wifi sub-board.
Could you please provide some instructions on the steps we need to follow?
by
Corey, you are right. I replaced. wifi board and it works.
Tks a lot.
Alexandre Bezerra.
by
Mine doesn't work and how do you replace the Wi-Fi module. This happened after i updated the system. Can someone explain to me how to replace the Wi-Fi board thingy? thanx
-Razor
by
Look in these guides for the wifi board guide Nintendo DSi XL
by
Show 1 more comment
Add a comment
I've replace the wi-fi board still no luck, any other suggestions?
Add a comment
Already replaced wifi module and same happens any advise?
1 Comment:
does this also work for dsi normal
by
Add a comment
Add a comment
Add your answer
Alexandre Bezerra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 15,960
