Repair and troubleshooting information for the Suzuki FA50 Moped.
72 Questions View all
Kickstart locked up, now won't start
So I slipped up on the kickstarter and it jammed up. I opened the crankcase and I could turn the crank with a wrench and it would go from really tight one turn to kind of tight the next. I put the case back together and still locked. I opened the magneto side and turned it backwards until it was easy to turn again. I put it all together and everything in the tranny worked because I tried to kick it a hundred times to get it started. Absolutely nothing. Did I mess up the timing or could I have blown the PEI ? And was it the reed valve that had the kick locked up and now it's damaged preventing it from starting? Any ideas on what to do or try? Thx.
Score 1
Is the kickstand connected to a kill switch? If so, the switch may be bad.
Add a comment
1 Answer
@kidice73 start by downloading the service manual for it from the bottom of this page Suzuki FA50 Moped Repair
Here is the wiring diagram with which you can check even further.
Let us know what you find.
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 55
