Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1106 Questions View all
Volume up key, arrow up key, and arrow right key work intermittently
So the volume up key, arrow right, arrow up, and plus/equals key only work when they want to. They're also linked somehow, if one works the others will work as well. Same when they dont work. All or none. They only function like 5% of the time. Any ideas? Thanks
Add a comment
1 Answer
Chosen Solution
Hi,the connector is loose.you will need to dissasemble enough to get to it.reatatch connector after cleaning it.
Score 1
Comments:
Thanks for the reply. I disconnected the connection. Checked it out everything seems ok with it. Reconnected and im still having the same issue
by
I take that back. I disconnected it and jammed it back in with some decent force. it works now thanks
by
Add a comment
Add your answer
Matt McGinnis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 28
