How can I remove super glue from bottom of iPhone 7
Was trying to bond my screw-driver to a stripped screw. Too much came out and is blocking access to the screw. Need it out so I can replace my cracked LCD.
You should be able to chip the super glue using a sharp knife point like an xacto blade. If the super glue is between the screw head and the case then gently cut as close to the screw head as possible to free the screw from the case. You may be able to etch into the super glue on the screw head to make a slot for a screw driver.
If that fails then try using a drill bit a little bit larger than the screw thread and just drill enough to cut the screw head off. You will be able to open the case and use needle nose pliers to remove the rest of the screw.
Thanks man. I’ll give it a shot when I get home
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
