Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
New screen on 3G but now Apple logo stuck + moving circle
I replaced a screen on a 3g the apple logo is stuck on with revolving circle constantly moving tried hard reboot and via computor still the same even tried replaceing everything exept the logic board still the same, does anyone think its a logic board problem Thanks Sorry did not replace the battery should i give that a try ???? please help
5 Comments
was the screen working before the change? or couldn't you tell? by screen do you mean lcd or digitiser?
any drop/water damage?
by
Do you get an error when restoring via itunes?
Possibly use irecovery to change the env to auto-boot true?
by
Hi Everyone, Thank you very much for help but found the problem I had replaced the mid frame including the digitizer so I replaced just a Dig onto the old mid frame hey presto its working fine can only presume the mid frame had someting to do with it Happy now Many thanks
by
did you try to restore via itunes.
i think is software problem.. just try first the basic troubleshooting... software first...
question.- what did you do last time before its happen?
by
take a look at kevins comments about this... he has sorted the problem out. It wasn't software
by
Add a comment
Chosen Solution
3 Comments:
Great job Kevin, now all you have to do is accept your answer so we all know that your case is closed.
by
What is a 'Dig' ?
by
@Michel, probably abbreviation for digitizer...
by
Add a comment
Most Helpful Answer
This is to help others with the problem:
Take the OEM part that you didnt replace, like the LCD and pop it onto the phone without the digitizer. One by one try parts like this. I have noticed that many aftermarket parts can cause endless boot issues. once the phone boots up, try installing the other part, and you will notice it sometimes freezes up. Quality control in China sucks, I can't tell you how many times I've had to troubleshoot like this.
Score 1
1 Comment:
Excellent point!
by
Add a comment
Add a comment
Add a comment
What is a 'Dig' ?
Add a comment
For me it was connector #3 that did it. disconnecting that cable lets me boot properly now.
1 Comment:
That means your #3 ribbon is damaged and causing a short and thus the loop. Replace that ribbon and see if that helps.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,733
