Repair guides and troubleshooting information for microwave ovens.
759 Questions View all
Will everything run, except heat, if you have a faulty door switch?
I have a Maytag Microwave, Model # MMV1174DS-1, which is appears identical to a Whirlpool. Everything appears to run on the microwave (fan, lights, turntable, sounds fine) except it doesn't heat anything. I replaced the diode yesterday. I tried it again after the diode replacement and nothing changed. However, the microwave heated up the water one time when I used the cook-Food Item #-Quantity sequence instead of just a timed cook. I thought I was on to something but I could not get it to heat again after about 15-20 more tries. So, I am thinking maybe it is a door switch that clicked just right, because if it was a high-current failure (diode, capacitor, or magnetron) the microwave would be able to heat after the part failure, right? Would a faulty door switch allow a microwave to run normally with the exception of producing heat?
Add a comment
I haven't seen a microwave that will run with the door open. Since the switch opens and closes a safety circuit, there isn't a "middle" position. It's a safety feature to contain the microwaves inside of the housing.
2 Comments:
Yes, that makes sense. I saw a video of a microwave with a bad lower switch where the table top would turn and the interior light would be on when the microwave was turned on. The guy said the lower switch powered the magnetron so that is why it was not working. I thought nothing should work if a switch was bad. I think this microwave is probably headed to the landfill .
by
or recycled, if possible
by
Add a comment
Most Maytag / Whirpool microwaves have either 3 or 4 door switches which are connected to mechanical cams driven by the door latches. With the use of cams, the switches are made to activate in a particular time sequence (one after another in rapid succession) to indicate to the control board that the door latch process is "successful". This feature is called a safety interlock, and it's design requires > 1 switch to prevent improper operation of the magnetron in case a single door switch sticks in the closed position.
Often the plastic cams or switches simply wear out (prematurely worn-out cams are often are caused by frequent door slamming), and the interlock stops working. In this case, the magnetron will no longer turn on (so, no heat), but the light and turntable will still work perfectly fine.
Replacement cams will run ~$35 (best case).
Add a comment
Add your answer
N Paul will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 35
All Time: 3,930
