The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
4069 Questions View all
MacBook won't charge or run on known good batteries, works on AC
My MacBook (mid 2007) recently stopped working on battery, I have to leave it plugged in to use it. This happened while it was restarting from a software update -- there was a small flash and noise (as apparently something fried itself) and now the battery won't function. I can see the battery charge level in the menu bar, so it will read the charge, it just won't work to power the computer or charge the battery. At first sometimes it would read "battery not charging" intermittently, but after a day or two it just went back to showing the level of charge.
I thought the battery had gone so I tried a new battery but I get the same thing. Any ideas as to what may have gone wrong? Should I try putting in a new battery connector/sleep sensor or does it seem like something else? It does sleep and wake up normally when I open and close the case.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
I'd at least take it apart and look at the battery connector cable, if its not the battery connector, its probably the logic board. The blessing and curse of such a simple design.
Comments:
Thanks, I'll do that -- I'll need to take it apart anyway since I don't know if it's the energy star model or not. Are there any other options or would it basically be one or the other (battery connector or logic board?)
by
I just replaced the battery connector and unfortunately that wasn't it. Are there any other things worth looking at or does it seem like it has to be the logic board now?
by
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,078
