Identified by model number G6U46UA.
2 Questions View all
Touchpad Pointer prematurely executes when it "hoovers" over something
When using the touchpad, and moving the pointer around, if it moves across an executable item, even "hovering" over it for a split second, it executes that command before you "click" on the touchpad left button as you would expect to do.
This is horrible, and I can't imagine that this is the way it's intended to work. Is this something that can be fixed with a setting change, driver change, or otherwise?
1 Comment
What Operating system are you using?
by
Add a comment
1 Answer
Chosen Solution
Looks like I've found a "fix"; in "settings", touchpad, turn off the "finger tapping" option -- this seems to have worked ok.
Add a comment
Add your answer
Byrne Whitehead will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
