Samsung tvWon’t turn on no red indicator light
My Samsung tv went out and it won’t turn on , there is no red indicator light on ,I’ve checked the cord and all connections , tv won’t go on
Update (01/21/2018)
c
c
@crazycars make sure that you give us your complete model number. This sounds like a power board issue. you will have to remove the back of your set (unplugged) and check the fuses on the power board for continuity. Check for any obvious damaged components. If that all checks out you want to plug the set in and see if you get power to the board by measuring the voltage on the fuses etc. Post some good pictures of the layout of the boards as well as the individual boards. That way we can see what you see. Use this guide Adding images to an existing question for that.
PSU BN44-00775A
start by checking the fuse for continuity
I have a neighbor coming later to help me get it down so I can take off the back,I’ll will also get all the info ,numbers and stuff. It’s only 2 years old ,bought it on sale , thought it was a good deal it has the 240 motion rate.Ill get everything up tonight so you can take a look and I’ll get my multi meter out also,Thanks for the reply
Hello , did you ever resolve this issue . I am currently dealing with the exact problem and dont know what to do next.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 11,403
1 Comment
The Model code is: un60H6203AFXZA
Version no# : GH02
Date of Manufacture: January 22,2015
Model no# : un6203AF
I didn’t see anything that looked off, the 6 capacitors looked good ,all were flat and the vents closed .I took pictures of both boards and some close ups .i haven’t located my multi meter so am going to borrow one tomorrow
by Katt
