Repair guides and support for televisions manufactured by Sony.
748 Questions View all
Sony KDL-32R330B suddenly went dark, but turn off/on &see image 1 sec
The Sony went dark, still has Green light. No error codes/red lights. Audio out is ok.
Press PIC OFF on the remote, then back on and you see video for 1 second. Same if you turn power off/on.
Optical out jack is lit red.
I checked all electrolytic's on power board with ESR meter.
I get 165vdc across the bridge rectifier.
Thats it... Ideas?
Add a comment
1 Answer
Chosen Solution
@allnorsky11 either bad power board or bad backlight array. Check the power board on the connector CN8601 if you get power to the LED
Score 1
2 Comments:
Hi Old Turkey! When the LED arrays are on for about 1 second, I measure about 30VDC on theCN8601 +- but only momentarily. I've disconnected the LED supply connector, I still momentarily read about 30vdc.
Does the power supply need feed back from the array in order to remain running?
My Mother uses this about 20 hours a day. I really appreciate your input.
Thank you!
Tom
by
@oldturkey03 no it should not need feedback. The supply should be delivered at all times. Double check the wiring to the LCD's and see if that looks okay. Could be a power board issue.
by
Add a comment
Add your answer
Thomas Erickson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 535
