Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
513 Questions View all
Will the laptop run w/ no CD ROM drive?
My CD ROM drive is shot. I don't want to replace it. Since I never use this CD ROM, I was wondering if I could remove it.
Will the laptop still boot and run normally w/ no CD ROM drive?
thanks and happy new year,
=brian
Update
Thank you for the replies. I will do so.
"If thy CD ROM drive offendeth thee, pluck it out."
=brian
Score 1
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Hi! Yes, it should work fine without a CD-ROM. Unless there's a reason you want to remove it, you could always leave it in place and save yourself the trouble.
Also, in case it's of interest, there are kits that let you mount a second hard drive in the CD-ROM bay, in case having more storage space would be more useful to you than an optical drive. If you're interested in one of those, let me know, and I'll find you a link.
Score 2
Add a comment
Yes u can. I used this exact machine for almost a month with no superdrive till i purchased a newer version of the original. Just follow the guides provided here. Some people even opt. to use the superdrive space for an extra drive. Depends on your specific needs.
Score 1
Add a comment
Yes, it will run, there's nothing about the superdrive that is required by the system to boot.
Add a comment
Add your answer
surfcow will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 882
