My LG washing machine model WD13020 has error message PF.
With clothes in the front-loader on Delicate setting, machine stopped before the Spin cycle. I pressed start, got error message PF then all to black again.
Tried many things, including the 'unplug replug, open close door 6 times' reset routine, and occasionally got to being able to see lighted dial and turn it either way before again PF then all to black. Once even momentarily had the pause screen for the 30 minute Quick program, but it went to PF then black before I could hit start. So clearly there is power there despite PF message.
What to do?
At the very least, how to drain the machine without flooding the floor, given the drain hose exits the machine casing above the water level, and the bottom drain hole is 1" above the ground and I have no container flat enough and voluminous enough to hold that much water.
Seren
3 Comments
The house is 7 years old, and I have a cable PI monitor on the power circuit which says all is well with the house wiring.
Australian plugs have no fuses and aren't unscrewable, and although I have a multimeter, new, I don't know how to use it without more risk to self and machine! So I guess it's one for the repair person.
Thanks for all the useful suggestions - it has excluded all the obvious causes. I'm very grateful. Oh, and I siphoned the drum and used a flat tray a dozen times to empty the filter and mopped up the residue.
Seren
by Serena Rule
Did you get this fixed. Mine is doing the exact same thing!
by Dan
mine is doing the same after numerous pf displays it doesn't power up anymore
any tip,advice please help
by trainee learner
