Do I need to purchase display adhesive assembly when replacing battery
Hello,
I would like to replace my I phone 6s battery. Should I reuse the screen adhesive or do I need to replace it with new screen adhesive?
Hello,
The pre-existing adhesive will be thoroughly damaged when you remove the screen. Technically speaking, you don't need to replace the adhesive, the phone will re-assemble fine and you will not see a difference. Apple was experimenting with the adhesive in preparation for the iPhone 7 which was rated as water-resistant.
However, if you replace the adhesive, you will not be able to achieve the same level of sealing as when it's done in the factory.
Full disclosure: I run a shop and I always replace the adhesive as a best practice. For DIY, it's not necessary but preferable.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,078
