Repair for speakers, stereos, header units, and CD players for your car or truck.
247 Questions View all
Alpine 3DE-7886R cartridge stuck within unit, cannot remove?
unable to remove the 3 CD cartridge from the head unit, have found an instruction manual on alpine uk's website.
It advises how to remove catridge manually by a inserting a special card, which i do not have.
Score -1
Add a comment
Chosen Solution
Order the card or make one.
Score 2
1 Comment:
Tried Alpine UK spares, they no longer have these in stock.
Need to make one if possible
by
Add a comment
Use a piece of thin strong plastic , I used the page separator from my diary , cut a strip about 30 mm wide , cut a piece out of one end startng about 15mm up one side of the strip approx 10MM deep , this leave a hooked effect at one end;
Slide this under the cassette and manouvere it towards the left until you get resistance hook onto this whilst still manouvering left until you hear /feela click , pull that cassette sucker out.
I found that the cassette was faulty, it would load and play two and three discs bit No one would play but it couldn't re-load it into the cassette , went error, then wouldn;t eject , it's qiute tricky to get the CD out as you have to extract the cassette with the tool described above and grab the CD all while the &%!@ thing is opening and closing
Score 1
1 Comment:
Thank's a lot !
The owner manual not describe that...
by
Add a comment
Thank's a lot for your answer !
My Alpine is okay to listening others music !
Add a comment
Add your answer
dave smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,308
