Display won't turn on after battery replacement
Hi y'all!
Last night I replaced the battery of my 2012 Retina MacBook Pro 15". After the new battery was in and the casing was screwed back I turned the MacBook on. Everything worked fine (few!).
Just like the repair manual said, I didn't plug the charger in and let the battery drain while I used it. At the end of the night, when the battery was empty and the computer turned off, I plugged the charger in and went to bed. (the charging light was orange)
This morning the charging light was green, so I turned my MacBook on again. I heard the fans whooshing, but the display stayed completely black (not even the bleedthrough of the backlight). I tried this a few times and every time it started up I heard the fans whooshing without anything happening to the display. I opened the laptop up again, and removed the battery cable from the motherboard for ~10 seconds before plugging it in again. This didn't help either.
I thought it might be a misplaced cable, but I didn't saw anything out of the ordinary. This is my first 'real' repair (except a few iPhone screen replacements), so I have no idea what the problem could be. Does anyone of you know what the problem could be? I made some close-up shots of the motherboard, which you can find here:
https://www.dropbox.com/sh/fphxsosik4pfg...
Thank you!
Ruben
the Netherlands
Update (01/12/2018)
I uploaded some better photo's of the connector here:
Before reconnecting
after reconnecting
Bottom
Top
