Guides and support for various television (TV) brands and styles.
9048 Questions View all
I have a Sharp LC60 LE741E 60" Tv totaly dead ,just went off
I have just got a Sharp LC60 LE741E and the man i got it off said ,I was watching it and it just went off ( now just dead ) No lights showing at all ,Any ideas chaps so i can attempt to fix this ,thnx in advance
Score 2
Add a comment
Chosen Solution
@moggy01 "No lights showing at all " always start with the power supply. Make sure you have power going to it. Then check the caps and fuses on the board. Work your way forward from there. follow the power rails to see where and when the power gets lost.
Score 4
2 Comments:
Thankyou for being helpfull @oldturkey03 i have read the chart and board shows no voltages ,main fuse and mosfet n diode and bridge rectifier is faulty so i have sent board for repair for £50 and then the tv will stand me at £100 and feel it is a bargain as i got sound bar wi-fi dongle and 3d glasses with it all sharpes brand, Which works out cheaper for me as not enough experiance and don`t want to bugger the board,I will let you know when its back and fitted with results , This will take a little over a week, many thnx
by
UPDATE :. Well i got the power board back all fixed and installed it ,switched tv on and only had the white V light blinking nowt else ,So i done some research on internet and followed advice which i unplugged the tv then pushed in power and volume up and held them in,then got the wife to plug tv back in while i still held both buttons in,once plugged in live i held them while tv led still flashed This lasted about 30 seconds then Wallahh TV came on and i then done a retune of the freeview channels and changed the setting to quickstart.Now on the night i can turn off tv onto standby and turn back on when i want to and no problems so far ,This has now been approx 3 weeks and alls well . The tv tech tod me he replaced components i mentioned in last comment . Thankyou for the advice @oldturkey03 as the pic u sent me here i got to the 3rd stage with no voltages ,which made my mind up about getting psu fixed .
by
Add a comment
Hello,
Smell the TV if you smell burning smell you can't repair.
Score 1
5 Comments:
There is no smell of burning and hasn`t been at a;; thnx
by
What about cable.
by
will check out cable tomorrow and get back to you ULEES Thankyou
by
Ok will se wen i will reply. (school)
by
lead is ok but a mosfet ,main fuse n bridge rectifier n a diode need replacing .I will let yous know how i get on but won`t be till next week thanks guys
by
Add a comment
Not a tv tech but i got hold of a Sharp LC-60LE741E led tv, blinking light, regular (every second), not powering on, tried holding buttons and plugging in to power, screen flashes after 30 secs then back to regular blinking light.
I sent the power board off for repair, but no difference, now swapped out main board and screen flashes for a split second with dvt and no input warnings, but still not working.
Is it worth swapping out the tcon board or anything else i can do/ send off for repair?? Thanks
Add a comment
Add your answer
moggy01 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 26,826
