The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Water damage, than new LogicBoard, better but still not working
Hello,
i spilled water on the table and it got into my MacBookPro. It went off and only did a very quiet beep when turning it on. It didn't change after drying it out. Than i found out how to clean a logic board. I bought 100% alcohol, took the MBP apart and cleaned the parts but it still would just make that quiet beep. The charger worked though.
I than gave it up and bought a new Logic Board. After i put everything together it now makes the start-sound but nothing else would work, no keyboard oder trackpad light, no light on the screen, even the fan is not spinning.
What could be the reason for this? I don't think they sent me a new logic board, that doesn't work. Any ideas on my problem?
5 Comments
do you have a link to the part you ordered? it may not have serials or OF
by
The Mother Board could be damaged and that could be where you are getting these problems from.
by
I don't have a link but it definitely has the same part number.
@Anthony: The mother board is another word for logic board, right? And if the new logic board is broken too, why would it make the apple start in contrast to my original logic board?
by
Is it possible that because of the trying to turn it on and off while liquid was in there, that all of it, the display, the keyboard, the touchpad and the fan got somehow roasted?
by
It sounds like the replacement board may be defective. Can you connect an external monitor, keyboard, and mouse to test? If those work, then the other built-in components may be fried, too (as Antonia mentioned), though that's exceedingly rare. It's far more likely to be a defective logic board than multiple failing components.
by
Add a comment
Most Helpful Answer
so im guessin that when you say new it is actually a used logic board and only new to you, what area of your old logic board had signs of damage, did you check the lcd connector, battery connector for signs of liquid damage, also try a new magsafe port
Score 1
Add a comment
I really recommend that you take the board back out and plug the magsafe into it and see if the fan spins - and I'm really sorry about how this will sound but you did check/replace the other water damage parts before you plugged them into this new board right? I'd start testing and inspecting parts and maybe plug your hard drive into an enclosure to see if it still has your data on it and is readable (back it up while you're at it)
Add a comment
Add your answer
Antonia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 64
