Why won't this iPhone boot up past apple logo?
I have tried to do the following:
Replace the front camera flex with an original one, use an original screen and even original home button.
I tried booting up the phone without the camera flex connected
I've tried to restart through ITunes both normally and DFU mode
It keeps getting stuck at the apple logo and won't go past.
Any suggestions?
4 Comments
Update: once restarted if plugged into iTunes, after a small setup in the computer you can view the specs of the phone like if you would if you plugged your idevice normally but the phone is still stuck at the apple logo
by Oscar Gamino
For some reason I booted it up and It actually worked, i set it up and everything and It was working, i decided to say wait and restarted it to see what would happen. And it's stuck on the logo once again, what's going on?
by Oscar Gamino
Could be just a faulty battery or battery needs to be charged up more.
by Ben
No i legitimately took the motherboard out and put it in another shell with all original parts including an original battery and it's still the same. I notice that after a reset. As soon as I unplug the whole screen and the battery, once I reinstall it and plug the battery back in, when I turn it on I have to hold the power and the volume button and manually restart it a couple of times then it finally gets to the set up screen.
Once in, it seems fine, but it starts glitchinh. It won't actually let me do phone calls or anything as it seems the proximity sensor and everything doesn't work even though the part is original and it does work with another motherboard
I'm curious as to what the problem is, is there an ic that needs to be changed? I thought it was the audio ic but it doesn't seem to have any issues with the audio, although it does still glitch out. Anything will help thanks
by Oscar Gamino
