Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 Questions View all
Starts but won't stay running
I was given the mower, it's been sitting s while. So I've replaced battery, selenoid, cleaned air filter, new gas(was empty). If I spray started fluid in under the air filter it will start but won't run. I also put carburetor cleaner in the gas tank but a half dozen cranks later over the next 30 minutes it still won't start. Not sure how to get to the carburetor and how to clean it if I do. Looked through many diagrams here with no luck. Help!
Score 1
Add a comment
You have a clogged carb, need to pull it off and clean it, most likely it is located under the seat if it is a mower like the one pictured. Also, if you follow the gas linie out of the gas tank it should lead you right to the carb.
Please post model #
2 Comments:
Murray Select model number on motor is 283707. I think I see it behind the frame, where the gas line goes into it. There's a cup like cylinder on the bottom. I guess take the nut off that and clean?
by
https://www.ereplacementparts.com/briggs...
Take off part 975A, to see if the fuel is gummed up, etc...then post back.
by
Add a comment
Remove carb. Clean carb and all internal parts float, jets, needle valve ect. Replace any gaskets if needed. Put carb back on and it'll run.
Add a comment
Add your answer
Andy Dosdall will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 50
All Time: 9,385
