Screen glitches, computer freezes/reboots when I touch bottom case
I've replaced the logic board, which did fix the problem with the ram coming unseated frequently. However, I am still having this problem where touching the left front (closest to me if the computer is open & facing me) quadrant of the lower case causes the screen glitch with barcodes then the system freezes & either auto-reboots or must be manually turned off & restarted.
Any thoughts? I was considering trying to construct a strong, secondary bottom case that attaches at the corners & gives a 1/2" gap to avoid touching that spot, but if someone knows what's causing this, I would much rather fix the problem!
Thanks in advance for your help!
