A collection of guides and support to help with washer repair.
3468 Questions View all
DRYER makes a loud noise during WASHER's final cycle
Hi
The washer is installed with a dryer stacked on top. During final spin of medium or higher, the dryer emits a loud noise which can be canceled by touching it, or by opening its door. I tried balancing the feet of each appliance, but it wasn't successful. Please advise.
I also have a video which demonstrates the type of noise it makes: https://streamable.com/xahxi
Thank you!
Add a comment
1 Answer
Chosen Solution
John craven - the final spin cycle of the washer creates the most movement. Something is shaking something loose. Check the hoses in the back to see if they are hitting something. Make sure the mounting brackets are tight. It could be a dozen things. Without being in front of the unit I can only guess.
Score 2
Add a comment
Add your answer
John Craven will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 183
