The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
PS3 doesn't boot, no video, green light
My PS3 60GB (CECHE01) recently stopped booting. I tried two new sets of cables, thinking it was my TV, but no luck. Next, I tried to access the Safe Mode/recovery menu, but still saw no output on the screen. I also tried Safe Mode on an old, composite input TV to rule out my primary TV—no love there either.
A controller connected to USB will not register; it just blinks all four LEDs slowly. It shows the same symptoms when connected with component and old-school composite cables. I have no HDMI available to test.
The green light is on, there's no "yellowish" light of death, and the HDD access light will blink once at boot, then stays off.
The HDD doesn't have any unusual noises (clicking, voice coil dead, etc.).
Since I can't even get into Safe Mode, does this mean it's motherboard or power supply?
Score 56
15 Comments
have you had any luck with it sagamore? im in the same boat
by
Hey Tom!
Sorry for the delay. I ended up sending it back to Sony for the $129 special. They shipped me out a new one. I suspect it is similar to the ylod, and if you have a hotplate ro reflow rig, you might be able to get whichever chip was loose reconnected, but I wan't set up for that.
by
I have the same problem
by
I'm having the same problem after returning from a plane trip. I suspect my luggage with my PS3 got knocked around pretty good in checked baggage.
by
My ps3 slim 160 gb started freezing then it got worst and worst then one day it just shut down and there was no light. then I clicked the power botton then the red came on then I did it again then it turn green but their was nothing on my TV screen then it shut off again.from thet day it kept on doing the same thing.I opened it and cleaned it and it didn't work and the fan and everything is OK but it won't stay on and display pixies in the sceen
by
Show 10 more comments
Add a comment
Chosen Solution
Have you tried holding down the power button at boot? While the PS3 is off, press and hold the power button until you get a second beep, then release the button. This should reset your PS3 to use whatever component cables are connected. This is necessary when you change component cables, especially when you switch from HDMI to regular cables.
I don't think its a power supply issue since you are getting a green light meaning the PS3 is turning on. If it was a bad HDD, then it would still turn on and would give you the HDD error code. And it's definitely not the yellow light of death.
It could be a bad input connection to the motherboard or a bad motherboard. I would try the HDMI. That might do the trick.
Score 17
13 Comments:
I'll see if I can get an HDMI connection, maybe that will at least give me an error code. I have reset the video, and also tried to get into Safe Mode, but it never outputs on the multi-av port.
And the two really weird things: No HDD activity, and controller never registers in safe mode, make me lean toward the MB. If it was just the AV port, I should still get a controller to register, even if I can't see anything.
Thanks!
by
Good luck!! I have had a few PS3s that wont boot or anything then after I have opened them up, clean them, reapply thermal paste and check all the connections they work just fine. Sometimes they get so much dust in them that it begins to cause problems.
If you cant get it working then I would try cleaning it before you replace the MB. A MB replacement should always be the last alternative.
by
Thanks so much much. I had my ps3 HDD removed and reserted and now its working perfectlyafter I had bown it.. the formal message of cannot start the appropriate system storage cannot be found is gone now.
by
The reset did the trick for me thanks
by
my ps3 starts for 30 seconds and then turns off by itself(no lights) when i press again it turns into red. need help.
by
Show 8 more comments
Add a comment
hey there i have had this problem i have fixed it :-) it only cost 20cents ... :-)
the problem with mine was no vid,no audio, cant geting to safe mode, takes discs blue light blinks but thning else....
the way i fixed it was open the unit remove rom,power,card reader ... you see the preasure plates for the GPU and the CPU take them off and put a coin (about 1.2mm thick)one coin in the middle where the preasure plate will go for both gpu and cpu... put it all back together push start and it will work... it worked for me ... really you need to reflow the gpu... green light means video yellow means cpu :-)
The gpu is coming away from the main board is the problem with mine :-)
hope this helps :-) i would say if you have it this far appart just change the thermo paste while your at it.....
post something on here if this helps you :-)
best thing about this fix is you dont blast it with heat to fix it...
Score 7
2 Comments:
I can't disassemble it bc I don't have the right tools. When I do tho I hope it works
by
If you use a small flathead screwdriver from a glasses repair kit ( make sure it's a flathead kit not a Philips screwdriver) it can replace the tork screwdriver.
by
Add a comment
remove the hard drive and press the power button twice quickly, then wait.
Score 6
2 Comments:
Hey there...When i turn my ps 3 on it blinks orange for two seconds then the orange light dissaperes but the ps is still on futhermore it doesnt display on my LG screen...Whats up???
by
Bit of an old threat but this worked for me when other methods didn't
by
Add a comment
i have a ps3 slim and when i turn it on the green light comes on and nothing comes on the tv, after a few seconds it the color turns to nothing its like the ps3 wasn't connected to the wall.
Score 3
6 Comments:
Me to and I can't figure out how to fix it
by
Mine does that when my control doesn't connect to the ps3
by
i have same thing im cryig cause its dead
by
Same thing. When I hit the power button again the red light comes on like I had just shut it off. But it was off with no lights. I feel like it's something silly to fix it. Just need some to tell me how. It's a snow day and I am desperate.
by
I have a question I get the green light and safe mode comes up but if I just turn it on it dose not work all all .. But the safe mode works .. If I try anything it just stays on that screen I tryed restart sysgem . reatore defult settings . restore file systems and rebuild database and restore ps3 system and system update it loads and loads thats it please e mail me at Daniel.bricks88@gmail.com
by
Show 1 more comment
Add a comment
it should be the hard drive , i had two ps3 the came in that would turn on fine except with no image or audio, the first one when i plugged the hdmi in it was extremly loose so i ruled it as the hdmi , it made sense that it would be the hdmi so i left it like that , the second one i had already worked on , it was having issues trying to format the hard drive and when it did it took a whole day, when the customer brought it back it was turnign no but with no image. so i thought to my self....hmmmm the hard drive was having problems before maybe if i test another one on there it could fix or make it better so i did and as soon as i installed a used one the video came on and i did had to format that hard drive and install an update but that got video and audio back on , thats not it , i got the first ps3 that i thought was the hdmi and i installed another used hard drive and got image on that ps3 again so wala
Score 3
3 Comments:
Does the controller connect to the ps3 when it does that
by
On me it doesn't work either recovery mode or normal boot . Are you sure to change the hard disk?
by
My ps3 could not reset after placing my hand on the power for more than 10 mins but the green light is on and my controller is also on but it’s also not functioning
by
Add a comment
Thank you! You helped me fix my daughters ps3! Red light was on when ps3 was off & when turned on ps3 green light would be on but nothing on TV this happened for 8 months. We hanged cords but nothing worked. Today I was about to purchase another ps3 but decided to search how to fix it. This post said to hold down the button when in off mode so I did for 10 seconds & it finally came on the screen. Thank you for your help!
Score 2
Add a comment
green light on and no video is a variation of the ylod
simply put follow the ylod repair instructions and you should be golden
this happen to me and thats how i fixed it
Score 1
Add a comment
I had the same problem in my CECHE01, sometimes it would turn on, then randomly this snowy, interlaced garble and if you pushed down dead center, it would go away, the device was still frozen and must be force-restarted, but you could tell it wasn't set right... I torqued down the screws a little tighter than i probably should have, but it fixed it.
Score 1
Add a comment
There is a thing called the green light of death and here's how I fixed mine
First flip your PS3 over there will be screws unscrew them then there is a black tab on one of them lift it up and unscrew that . In the front of it there will be black screws then you need to go to lows and ask for a t10 star torch (type of screwdriver head cheap) then once u get that then unscrew them then take off the lid and then clean your PS3 put screw the lid back on . I hope u get your PS3 running sagamore and good luck with it
Add a comment
You have to make sure your yellow cable is operational and all the way in so check that if it doesn't work then blow in the hole and then it should work
1 Comment:
Make sure your on the right input
by
Add a comment
My problem was with the video cable, I had the exact same symptoms and even if the PS3 DID turn on, it kept crashing. The bad cable was the AV-MULTI OUT and my theory is that the cable may have been short circuiting the PS3. I connected it via HDMI and have had no problems since!
3 Comments:
Hey i have problem with my ps3 super slim it doenot shows anything no light appears nothing happen always keeps turn offf plzz help
by
My ps3 super slim 500gb model will plug in power cord and it lights up red then 30 sec later it will be and turn green(pushing on power button won't work) so it turns on. Fan won't work either. Then it turns off after a min or two. Wat caused this whole problem was I cut into the fan wires and was hooking up a fan controller and I think I fried something. Idk. Plzzzzzzz help!!!! I've tore it down to the mother board and nothing is wrong. The power supply looks great. Nothing swollen or anything. Changed out the fuse and nothing. Still does the same thing.
by
Bro open ur ps3 super slim mother board and apply some heat with heat gun on both cpu and gpu and the above ics and apply some thermal paste on cpu and gpu and fix it up and now power on !
by
Add a comment
I've tried all of these methods and still got the green light and one HDD blink when I turn it on and shuts back off around 30 seconds and isn't YLOD or RLOD.
4 Comments:
Im having the same problem.the problem is you came across a modder/hacker this sead person for what ever reason.has put a bug in your ps3.as soon as you turn it on the bug that this person put in your console.tells the console to shut off.
by
Is this for real. We have been hacked? How do we Un-Hack it. And why would someone do that we only play the tutorial for minecraft. That's it.
by
by
Yes you can be hacked don't mader if you play story or not.anyone that plays GTA5 or other games online what there after is your account.if you start haveing problems signing into e-mail or your playstaion account that is them hacking you.only way to avoid it is not to sign in to psn.your console at that point is your accont psn is only for online play an store...Avoid puting your online gamer tag out there.
by
Add a comment
What worked for me was to unplug my HDMI cable then plug it back in. One side at a time. And it worked! So glad that it did.
Add a comment
IM SAD IM SCREAMING IF MY PS3 IS DEAD ITS LIKE BLACK URN O RED AGAIN GREEN THEN BOOM OFF IS MY PS3 DDEAD
2 Comments:
Exact problem I am having.. Sometimes it will power on and play fine, then other times it will go from blank to red light then green light then off immediately
by
Much money pay for Sony PS3 and PS4 should live up to their name it's sad that PS3 have issue and Sony doesn't help issue That's unprofessional and it's your money support this company Sony if wasn't for gamer people's wouldn't make a profit at all . What guarantee have on PS5 and money you spend it's sad don't live up to standard quality
by
Add a comment
Add your answer
Sagamore will be eternally grateful.
Past 24 Hours: 26
Past 7 Days: 263
Past 30 Days: 1,044
All Time: 326,617
