Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
ApplePay no longer works (NFC antenna?)
When iPhone 6 was new ApplePay worked fine. After 6 months it would work intermittently, then about a year from purchase stopped working entirely. I took it to Apple Genius Bar. They worked with it for about 2 hours and finally said it was a hardware problem-wanted $180 to fix. After I uploaded iOS 11 on a lark I tried ApplePay again. It worked flawlessly for 5 charges. Now it activates when held near merchant's reader, but when I try to pay message of 'Holder near reader' appears and I can't make payment.
Score 5
6 Comments
Hi David, I have this exact same issue. Apple pay is not fully broken, but works unreliably. Now, 2 months from the fix, may I ask if Apple Pay is still working on your phone?
by
Andrew,
You asked at an interesting time. Since l tightened the screws it has worked flawlessly dozens of times at many different retail stores until yesterday. I had my first failure at a Panera store. As I had used ApplePay twice the day before at a Whole Foods and Earthfare without incident, I'm hoping the failure was because of the merchant's device and not my iPhone. Since my apparent fix I have successfully used my ApplePay at several stores where the cashier has told me that people using ApplePay have been only intermittently successful.
Dave
by
3 months+ since tightening the 2 screws securing bracket attaching NFC chip to frame and mine is still working great at multiple different retailers.
by
Does anyone know if the quick start on ios 11 use NFC
by
Where is the location of the screws?
by
Show 1 more comment
Add a comment
Chosen Solution
The NFC antenna is housed within the top part of the bezel. That means there is no real antenna to replace unless you replace the entire housing. It is possible however that the NFC Bracket interconnect is damaged or was disconnected in a previous repair attempt. Follow this guide, specifically steps 33-34.
Score 2
6 Comments:
I opened iPhone case and tightened the 2 screws that secure the NFC bracket interconnect. Thus far I have successfully made 2 charges using ApplePay. Very hopeful the problem is solved; however, because of intermittent function in past I'll wait until I transact several more charges before celebrating.
by
Don't forget to come back here and let us know if you celebrate... :-).
by
I certainly will. Immediately before opening iPhone and tightening screws I tried ApplePay and it failed so I believe the odds are high that this quick fix solved the problem. If true I may contact Apple and suggest they re-title the "Genius Bar."
by
7 successive successful transactions at 3 different Paneras, Whole Foods, a local liquor store and Discount Tire. At 3 locations I was warned that the people trying to use ApplePay have variable success at the terminal. Mine worked flawlessly. I'd be interested to know if some of people who had issues had a bad antenna connection. I will not post any more follow-ups unless my ApplePay ceases to function.
by
That's great news!
by
Show 1 more comment
Add a comment
Hello . I have the same problem on iphone 6s. I bring it to the terminal - the wallet starts - and writes it to the device - the finger is scanned and the payment does not go on. I changed the NFC antenna and tightened all the bolts. nothing changes, what should I do next?
Score 1
1 Comment:
The same thing happens to me. I have an iPhone 6, I have added my card to my Apple pay wallet and allowed Apple pay through my mobile banking app. I go to the pay terminal unlock the phone but nothing happens when my phone is placed directly on the Apple pay card reader.
I have replaced the 'NFC bracket interconnect flex' that has a little blue capacitor underneath and screws underneath the metal camera bracket. I have also replaced the F shape WiFi antenna flex. The only thing I can think of now is that the NFC chip may be broken or the little bracket that connects the motherboard to the aluminium housing at the top left of the camera but that’s just a little piece of metal so how could that be broken?
Any help will be appreciated however I fear that the NFC chip is broken as I don't know what else could be causing the problem.
by
Add a comment
I know I’m a little late to the party, but I have to throw in my two cents for anybody that is still having this problem. In short, I rebuilt my iPhone. Everything worked flawlessly. That is, except for Apple Pay. I realized this once I went to a restaurant and attempted to use Apple Pay to purchase the food, but to no avail.
So I then reopened the phone and realized that the problem laid within my re-placement of the NFC bracket interconnect, and that it was not seated correctly to ensure an electrical connection. I didn’t take any pictures to describe what I’m talking about. There’re pictures of what I’m talking about in the iFixit guide listed above, but to describe in words; the upper part of the interconnect bracket must be seated under the camera bracket, instead of over it. If placed over it (like I had it), then the plastic part of the camera bracket will act as a insulator, therefore stopping the near field communication signal from consistent successful transmission. The metal (copper) part of the interconnect needs to be touching the metal part of the housing, and screwed down tightly but not overly tight, to ensure a secure electrical connection to the antenna of the iPhone.
I hope this helps somebody out there!
-Seth
Add a comment
Add your answer
David Edwards will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 59
All Time: 39,913
