SMD resistors value on F&P motor control board SD P7CP ver 48 2010
What caused the problem:
chlorine bleach solution dripped into the motor control board. When the machine was turned on, it sparked and audibly fused and ceased to function.
What I have done:
I extracted the control board from the washing machine.
See photo of the board.
The only visible damage is the two fused SMD resistors seen in the photograph next to the two capacitors.
The visible value of the two blown SMD resistors was destroyed in the short.
What I want to find out:
I want to know their resistance-value so I can replace them.
There appears to be no other damage to the printed circuit board.
Any advice about this problem will be gratefully received, especially knowledge of the resistance-value. I can then replace the resistors and reinsert the board and test for other possible damage.
The Fisher and Paykel upright washing machine Model is WA75T65GW1
The Motor Control Panel board says:
SD P7CP Ver 48 11:40:49 11/03/10
421389NAP (062525)
2 Comments
Thank You Jayeff. Your answer fixed it. I am very impressed
by Anna Killigrew
For anyone else finding this page, on the 420768-A revision of this board, they are 0.24 Ω (R240)
by Anthony Cross
