The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
306 Questions View all
Console turns up automatically,fan speeds up really high,no ring light
Hello
I had my console for about two weeks ago. Few days ago after finishing playing a game (for about 2 hours) I turned off the console(xbox 360 s) from the Xbox home settings on the controller. The console switched off and automatically came back on. I managed to switch it off with the console's power switch. Later when I tried to switch on the game console, no power.
There was only the beep sound of the power switch and the eject button. Few days later i switched the power cable on, and touched the power button, the console turned on and 4 seconds later it went off. I have tried other several online solution, changing the power brick, checking the USB but no power.
After reading one solution, I decided to open the faceplate and clean/check the power ribbon, if it's okay. I also cleaned the power switch with a cleaning brush. After that when I insert the power cable to the console, I can only hear the power switch beep and the fan of the console turns up automatically, and it goes really high. But there is no light on the power switch. The fun just goes really fast. The game will not start.
Please help.
15 Comments:
So the fan is going full speed. is the Xbox actually heating up causing the fan to do that or is the fan just running at full speed for no apparent reason?
by
Yes the fan just running full speed.
by
And have to disconnect the power cable to switch if off
by
So its not heating up?
by
Yes no heating
by
Show 10 more comments
Add a comment
Leave it for an hour or so (power on) and see what happens. That should fix it if it is doing background downloads if it still does not work, we have that ruled out.
18 Comments:
Okay, I will try that.
by
Should the hard drive be in or out?
by
was the harddrive out the whole time you've been having this issue? how long has it been out?
by
I removed it when taking the Xbox apart to take of the face plate, that was yesterday
by
Do you have this issue when the drive is in?
by
Show 13 more comments
Add a comment
Take a look here: Xbox 360 Troubleshooting
1 Comment:
I have check that, how can I know if the problem is from the RF module or the power switch
by
Add a comment
Add your answer
Confidence Asamoah will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,964
