Found a dime (coin) inside the DVD drive when replacing the battery
When replacing the battery on my device I see a dime inside the protective cover on the DVD drive. I assume it is not supposed to be there, but would appreciate advice about this and how to get it out.
Thank you.
Rosalie
Update (12/15/2017)
OK, I tried to lift the plastic sheet but it was adhered tightly and would not lift up. So, I carefully scored a small cut in the plastic by the dime and then pushed from the other side of the dime with a very small screwdriver through one of the openings in the plastic where screws are located. The dime gradually was pushed through the cut opening and is now out. I then placed a small piece of tape over the cut hole to seal it.
Now to see if the DVD drive works and if the battery will function as well.
1 Comment
Too bad it wasn't a Mercury (collector's item - silver) dime...
by Warren Buckles
