The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Questions View all
Laptop wont run on battery power.
I bought my daughter this new MacBook Air.
But within 2 months at college she spilled part of a glass of water into the keyboard. It was not plugged into AC power, just on battery at the time.
She said the laptop shut off immediately. She quickly inverted the laptop and tried drying off any moisture with a towel. She called me and I told her not to try to power anything up.
She brought it home and I rigged up a fan to blow on the underside of the open laptop for 48 hours. I plugged it in and it powered up fine, operated fine, and the only problem I noticed was if the AC cord was removed it would shut off immediately!
She was in the middle of finals and needed her notes so she took the laptop back to school for a few days until the semester ended.
I decided to order in a new battery and a IFIXIT tool kit (fantastic) to replace a possible shorted battery in the mean time.
She took it to the Apple store because it was still under warranty but the store told her there had been water damage and the laptop had to be replaced at her expense!
So I took the battery out and tried cleaning up what seemed like corrosion around a few components with alcohol and swabs. I tried again to boot up on the new battery and nothing happened but the charging light on the MagSafe connector came on.
No screen, but the keyboard lit up. I did a forced shut off and began a total teardown of the motherboard/logic board, I/O etc to eliminated corrosion or deposits in as many removable assemblies as possible. I put everything back together after cleaning it all topside and bottom side of each. Powered it up and everything came to life and the new battery indicated 98% but finished charging to 100%.
The only problem is it will not use the battery for power. It has to remain on AC plugged in to work. I did use CoconutBattery health app and it indicated a fully charged brand new battery with no cycles yet.
Can anyone tell me what component may be the culprit here? Thanks
7 Comments
Thank You Thank You! You rock! What an amazing community. You make it possible for persons to repair their own products and avoid the commercial rip offs out there. I truly appreciate this help...
by
So I located the schematic of my motherboard (820-00165-A) and found the suspected resistor in PPBUS_G3H that is causing my problem based on the video suggested in this thread. I found the schematic of the board and believe its R7006. My problem is scouring the internet I couldn't actually locate the physical location on the motherboard. Is there a searchable way to find a particular component on a board, without having a subscription or more specialized equipment? Can anyone provide a picture circling the physical R7006 resistor? I have a new resistor on order to replace it in the coming weeks. Thank You
by
[image|1301133] Here is the schematic of R7006
by
I have the same issue. Can you help me out?
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
Watch this video from Louis Rossmann see if it helps: Macbook logic board recognizes battery but won't run off of the battery
Score 3
4 Comments:
Excellent solution. Video and description were spot on. Now I have to locate a new resistor specified in the video. Any recommended places a person could buy one?
by
the resistor cost less than 1c literally. IMO I would buy an 820-3437 or 820-00165 with a hole in it from places like aliexpress for $15 at least then you could replace any other components needed. there will be multiple resistors with that same value if you happen to lose the first one. Trust me Its too easy for them to grow wings and vanish.
No offense but just because someone elses problem was resolved by replacing R706 it does not mean this will fix your problem. you mentioned there was corrosion on the board??? id be checking those areas to see if they are related to the battery.
Goodluck with the repair.
by
joe, guessing that this was asked last year it has probably been fixed by now
by
Like Joe my philosophy is better late than never. These late answers/ comments can still be valuable. Like Joe says, just because replacing one particular resistor on a board with an issue fixed that board, there is no guarantee that replacing that same component in another board will fix its issues. Fixing electronics is not that simple otherwise monkeys could do it ? You need to understand how the circuit works and inspect, measure and diagnose the issue.
by
Add a comment
Add your answer
Brian Rindfleisch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,698
