2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
939 Questions View all
My HD not mounting after new install. What could be the problem?
I just installed a WD3200bekt HD in my MacBook Pro 15" 2.2Ghz A1226 laptop because I just wanted some more room. After the install the Disk Utility could not see the new HD so I could not partition it. I checked all of the connections and they seemed fine but still had the same problem when I used disc utility from the boot disc. I then reinstalled the old HD and am now not even able to see it either. I have no idea how to approach this problem. Again my old drive was working fine when I took it out for the new install. Any help would be greatly appreciated.
Comments:
Was the old hard drive working before you started?
by
Yes it was working fine. I just needed a bigger HD.
by
Thanks, I will give it a try...
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Hard Drive Flex Cable, Apple part number 922-8045
Check both connections on the hard drive and logic board. Unless you zapped something, that's the only thing it can be.
Score 3
Comments:
I just received the part that you recommended and it worked great. Thanks a lot for your help..
by
Glad I could help solve your problem
by
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 637
