Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 Questions View all
Won't Turn On
Within the past 6-7 years, I have been through 2 powerbook G4's The first one was a 15" Powerbook Titanium DVI, one morning it wouldn't start, and I decided to take it to a computer repair place, since i don't live near an apple store, and they couldn't fix it, but said that they could try a new logic board, for a few hundred bucks, so i decided to just replace it with a 17" 1.67Ghz Low-Rez PB G4 Aluminum. The First powerbook wouldn't start at all, the CD drive would appear to spin up, and than the Computer would heat up near the cpu, like it would as if it was on, but that was about it, also, caps lock would work on the keyboard (the light would turn on) and for some strange reason, F5 would turn on the num lock light instead of the num lock key. The second powerbook worked for about 2 years, but one day, i dropped it, and it worked, i picked it up, and continued to use it, and later shut it off, to charge it. Upon turning it back on, it wouldn't work, no boot, no chime, no video, it was completly dead just like the other one, the drive would spin, and it would get warm, but nothing else, and just like the other one, the caps lock worked, and the F5 key would turn on num lock, just like the other one, i took it to the computer repair place, just like the last one, and they checked for basic fults, dislodged cables, ram, ect, but found nothing, and offered to replace the logic board again, but i decided to just let it sit in a corner, and wait for the price of PowerBook G4 parts to go down, so i might replace it, unfortionatly it's still 800$ for a new baord, and doesn't really seem worth it, but i was wondering if there ware any commonly known issues with these computer's that would cause symptoms like these, and if i might be able to fix somthing, and save the computer.
Thanks,
Chris
Add a comment
Chosen Solution
If you check on ebay you can get the 1.67 low res logic board for + - $300. Before buying a new board you could try to boot from your installation disk or external firewire drive cause the hard drive could be the problem or try to replace the DC in board.
Score 3
1 Comment:
Laptopaid has on for $242. Ralph
by
Add a comment
Hi Chris!
Did you solved the problem with your notebooks? I have a similar problem. Once my laptop asleep and did not want to wake up. I turned it off by pressing the power button for 10 sec and then he does not want to turn on again. When I pressing the power button the fan under the keyboard starts spinning 1 second and nothing else happens more. I tried everything that is described in this website, but nothing helps. Sometimes it turns on and works, but if you turning it off, it is no longer included.
Givi
Add a comment
Add your answer
Chris Green will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,577
