Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Help!, half of my iPhone 6's screen is black.
Half of my screen is black, although all the other features of the iPhone work fine, which is strange. I was outdoors, and I fell on my leg, landing where My phone was, in my pocket. (Screen has not been cracked).
(I have tried powering off my phone off and on, but nothing changed.)
The screen itself works technically , but since the display is black it is extremely difficult to use my iPhone, and I really need help because I I can't buy another iPhone due to the price. Thank you for reading my message.
Score 3
3 Comments
I have the same phone as you and the same problem
by
Same here, how do I fix it?
by
Same thing here but I also have some red and green specs/ dots
by
Add a comment
This answer was originally to another question.
This response is late but hopefully it can help others.
There are two possible causes here. One is a damaged screen assembly. This can be easily replaced by ordering this part and following this guide.
The other possibility is that the backlight circuit was damaged and needs to be repaired. This requires a micro-soldering repair and is not DIY .
iPhone 6 Screen Image
Product
iPhone 6 Screen
$44.99
Score 1
Add a comment
Most Helpful Answer
To fix iPhone black screen of death, you can also restore your iPhone through iTunes. However, please make sure you have backed up all your important data from your iPhone via iTunes to restore iPhone with the iTunes backup. And during the process, iTunes will erase all data and settings on your iPhone to fix your iPhone. Now, you can start to fix your iPhone black screen issue.
> Firstly, get a USB cord to link your iPhone to computer and launch iTunes on computer.
> Secondly, click the iPhone icon on iTunes, then hit the Restore iPhone option on the right panel on iTunes window.
> Finally, confirm your action to restore your iPhone on the pop-up window. Then iTunes will start to erase all data and settings on your iPhone, download and install the latest iOS version on your iPhone. Finishing the process, your iPhone black screen issue will be fixed.
Score 1
Add a comment
your only option is to replace the whole screen!hope that helps or check the led wires
Add a comment
You could ask for help from a professional iOS rescue tool - iOS System Recovery to fix your iPhone error. This tool specializes in fixing all types of system problems on iPhone. You can easily operate the program and quickly fix different problems like stuck on Apple logo, iPhone error 9006/53/56, iPhone stuck on recovery mode, iPhone blue/black/white/red screen of death and so on.
Add a comment
Add your answer
K.Coleman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 24,294
