Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2689 Questions View all
iPhone 6s stuck on bootloop after screen replacement (With Pictures)
I have an Iphone 6s stuck on a boot loop after i changed the screen, everything was done right as I've checked my work over multiple times. The phone turns on and stays on the boot screen for about 5 minutes and shuts down and starts all over again. One thing to consider is that the phone does not have the metal plate covering the screen/camera flex cables, and it does not have the plate covering the battery flex. Could this be an issue with my camera flex? or perhaps the motherboard?, any input is appreciated.
I have attached some pictures here
Edit: The phone is recognized by itunes and enters the recovery mode screen. I don't want to update the phone but i dont mind restoring. Weird thing to note is that whenever i reset my phone (Home Button + Lock Button) the screen does a weird glitch and turns purple then shuts off.
Score 1
Add a comment
1 Answer
Most Helpful Answer
its possibly a faulty screen, try it with another
Score 1
3 Comments:
I tried using the old phone screen which has a crack, i ordered a new one from a trust worthy seller and im having the same issue. Any other suggestions?
by
was the phone liquid damaged as i can see the indicator is red
by
Yes, but it was prior, about 2 years ago and the phone had no issues since. The only reason why its being repaired its cause of a screen crack.
by
Add a comment
Add your answer
Allen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 151
