Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Sound only working when logic board is presed
This is an update to an older question I have asked since it was pretty vague. So when I was disconnecting the battery of the phone i used a screwdriver which caused a spark and after that the sound would only work if i pressed the area above the sim card slot.
Add a comment
1 Answer
Most Helpful Answer
since you say there was a spark when disconnecting the battery you could have maybe damaged the audio amplifier or surrounding components which is on the other side of the board behind the battery connector and has a path to the battery line ( pp_batt_vcc )
Score 1
Add a comment
Add your answer
Axel Salas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
