The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 Questions View all
Question Closed
I'm thinking of updating
The software works great. I'm thinking of upgrading the processer
and the video card. I have a 733mghrtz cpu single core and the 32mb vedio card. memory at 1gb and a 60gb hard drive currently.
Mt goal is ti stream video and live feed from the internet.
Is it possable with this computer or even worth it.
All feed back and ideas are welcome.
Thanks Guys Stephen
Add a comment
1 Answer
Chosen Solution
NewerTech, XLR and FastMac all made processor upgrades for your machine. Currently only Newer still has them that I know of: http://www.newertech.com/products/maxpow...
I've done probably twenty of them and had very good luck with only one failure (that FastMac replaced). Doing it is very simple. I would also max out the RAM at 1.5 GIGs.
You will be be able to run OS 10.5.8 max
Score 3
1 Comment:
Wipe the HD, reinstall OS and Keep your it fairly empty, the larger ram will want more space for a swap file, and if it defragged it will work better.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 716
