Just for completion sake since the OP never got an answer. It may still be relevant for anybody with this TV model.
First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
Vizio's are (were) known to have pretty bad backlight strips and even in this case it does sound like that was the issue. To find out what strips are in that, always remove the back cover and check the label on the back of the LCD panel. That will identify the exact panel number and the maker of that panel. Using those numbers for an online search usually shows multiple sellers.
The no video issue can also be related to a bad backlight inverter circuitry. That circuit is on your power supply. unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. It is possible that this is a power board issue. Measure the voltages on the LED connectors on your power board (DC voltage) and ensure that those are all the same. Commonly for a TV this size, if the voltage is <50VDC then it is a power board issue.
