Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
462 Questions View all
Potental signs of a failing harddrive?
Hello
I am in a debate with my Mac in regards to the Hard drive
It always has a filesystem corruption more often then normal
and i end up with permission issues in the same fashion but this time was 14 and sometimes it is more or less then that count
Will update as more issues arise that could help
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
I would back the drive up to an external using Time Machine. Then start up from your system installation disk. Go to the second screen pull down men to Utilities -> Disk Utility. Select the drive on the left and reformat the drive using the write zero's option. This will map out any bad blocks that may have developed and not write to them anymore. Repairing errors and then rewriting to those same bad blocks will just keep giving you errors till something that the system has to have gets written to them, then it's reinstall the system and hope your system doesn't hit the same pot hole. After the drive is zeroed, use migration assistant to bring your data back. Then run the repair till its clear. After doing all this and you still have problems, it's time for a new drive.
Score 2
Add a comment
Have you run Techtools Deluxe yet on it? Also check the SMART status of the drive under Disk Utility see if its failed.. In the interim, make sure you back everything up on time machine...
Score 1
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,329
