Can't connect printer to wifi
I have an Epson XP-245 printer, purchased a few months ago. Until recently, it has worked perfectly, but now wifi connection is cut and I am unable to re-establish connection. I have followed the instructions in the manual several times. I have switched off/on the router, and pressed the WPS button (several times in last few days). When I press the printer wifi button, the red and green LEDs flash alternately, but the result is always the same: finally, only red light on and no connection. Can you help?
Score 1
Comments:
Hey Suzy. In this case, especially if the WiFi cut suddenly, my guess is that there is a hardware or software problem with the printer. In the case of software, try to update or restart your printer. In the case of hardware, my suggestion would be to use a wired connection to your computer or router instead of trying to repair it.
by
Add a comment
