The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
72 Questions View all
My calculator won't charge and I replaced battery, still won't charge.
My calculator won't charge and I've replaced the battery and I've used the usb cable the calculator comes with to try and charge it. Still nothing. What do I do to fix this?
Comments:
I'm sorry I've never heard of this issue before. My only solution is to push the cable into the calculators USB port harder, this solution is usually only good for data transfer issues. When you put the fresh battery into the calculator did it turn on and operate normally? (besides not charging). Other than that, it sounds like a hardware failure or defect to me. You'll probably have to return it.
by
Add a comment
1 Answer
Check that the battery is in good condition and that it's making proper connection to the board. The only other thing I would suggest is open it up, inspect the charging port, if all looks good try using another cable if not either try to replace the port if it's faulty or return the item.
Add a comment
Add your answer
Maha Mohammad will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,688
