Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Two Touch lines are not working (not an issue with the Display )
iPhone 5s -64GB
`two touch lines are not working in right side of the screen I have changed the display but same problem.there no issue with the display. can it repaired ? is this a issue with touch connector or touch IC?
Add a comment
1 Answer
Check connections are all fitted and firmly in place if they are try cleaning all contacts. Try a different screen from a different supplier as it maybe a manufacturing defect on the screens. If problem continues after the checks then there will be other options to find problem.
3 Comments:
I have checked all those. every display is same right side won't responsive.
by
Even a display from a different supplier ? Try gsm forum as they will have more in depth information when it comes to board level repair possibly a schematic and a jumper solution to your problem. Hope that helps.
by
yes.I'll try .Thank you !
by
Add a comment
Add your answer
Ramesh Dilran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 30
