The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
37 Questions View all
Why are instrument panel lights and tailights not working?
All lights work except instrument panel and tail lights. Checked lamps in tailight and they are fine.
Add a comment
1 Answer
Chosen Solution
Harry what year is your Jeep and where are you located? Do you the optional daylight running lights? Anyhow you checked the bulbs, did you check the fuses? Did you check the wiring to make sure they are not shortened out. If those check out okay, I'd concentrate on the switch. Here is some more info Good Luck
Score 2
Add a comment
Add your answer
Harry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 938
